Hi All!
New to the forum- just re-boarded and reskimmed the kitchen ceiling with finishing plaster due to the old one being hideously boarded and papered, before a textured finish to cover the awful work.
Now I've ballsed it up a bit. Scrim taped and filled, left to dry completely then applied 1-2mm finishing plaster- not a perfect finish after troweling so decided on a second coat, just to fill the gaps, but it was getting late. So the next day, when fully dried out I've just started applying a second coat, thinking a spray of water on the first coat will be enough to control suction. WRONG!
The second coat (mixed very wet) is going on and drying so fast it's unworkable, and becoming bubbly and impossible to trowel flat. I'm guessing I have completely wasted my time and I need to PVA over first coat and apply 2 new coats but I would love it if I'm wrong and someone has a fix for this? Second coat doesn't have to be finishing plaster if filler or something would work.
Any ideas? Thanks! :RpS_cursing:
