S a plastering
how much water in ml per 25kg tub of silicone do you normally put in just might need some in this heck I've been sent just seems a tad thick just want to bring a bit of fat into the mix thanks
One thing I will mention, this has come from various manufacturers, not the salesmen but the chemists behind the products:
One of the cheapest ingredients to put in the T/C would be water, if it was required they would add it. You need to be aware adding too much water will affect drying times and also the dispersion of the colourants. If you have a tinted top coat and add different amounts of water into each tub you can cause a colour variation.
