Replacing tiles on a window bay
MickyC0501
Hi. After a bit of advice please. I’ve been asked to remove the tiles from a bay window & replace with render. I was planning to fit a cement board to the framework, then eml & sand & cement on top of that? Would that be ok in your opinion? Many thanks
  • Replacing tiles on a window bay
@Casper
Re tile /or Clad it in pvc /up the insulation in spars . Less hassle .
Strp the tiles away and use eps boards then base coat and mesh it don't use sand and cement there's loads of baged base coates about to go over it
