Render board over pebble dash
cian_w
Hey,
Just moved into a bungalow which has a sand & cement plaster over old pebbledash. The plaster job looks awful and is fairly bumpy. We got downlights put in the soffit and at night the bad plastering really stands out.
I'm trying to figure out the best way to get a new smooth finish on the front of the house. I was looking at the 20mm external insulation but not sure I want that foamy exterior that can be dented/damaged easily.
If I were the remove the current plaster and maybe apply a render board to the pebbledash? Is there anything out there that could help.
Thanks!
Knock loose off jet wash rendagrip the lot scratch on with silver sand bed mesh in another tight coat n top the cnt off!
Hack it all off . apply pva, two coats s and c job done.
  • Like
Reactions: Djr
Never fell off yet. Chuck pva in scratch coat. Then pva scratch coat before top coat. Bob's you're auntie.
@cian_w We would be more than happy to come and take a look at this for you. We are a rendering manufacture of everything render. If you can send me your details and whereabouts of the property we can arrange to come have a look and see what the best options are moving forward.
