Evening All,
I only saw an EWI forum, not a IWI so apologies if this is the wrong section.
I'm just doing up an old 2 bed terraced that has solid brick walls. Rendered on the outside which has been checked for condition and I am likely to also have a new liquid damp proof installed.
I want to install insulated plasterboard on the inside of the external walls.
I was wondering what we're best practices to ensure you prevent a build up of condensation on the internal brick surface?
Dot & Dab or Timber Frame, Vapour Barrier, Air Tight sealing, etc?
Cheers
Russ
Cheers
Russ
