Hidden fascia board
tycho
Hi there,
Im after a hidden fascia look below (new build).
Can I just bring fascia board flush with EWI and plaster over both with mesh?
... or should I tac on a 6mm cement board to fascia first?
th
1. why are you using ewi on a newbuild?
2. take it youll be using 90mm? or there abouts?
i would pland a 3x2 timber where fascia would go. then notch the eps over the timber amd render.then you have a.fixing point for your gutters.
i would however ask nhbc what their thoughts are on it
interesting, thanks
hadn't thought of putting eps over timber
Would there be much risk of cracking across the two different materials (EPS and cement board)?
Maybe i should be using a high-strength mesh like Panzer across the interface?
