Alsecco
duke163
Has anyone used this product ? I've been asked to quote for 2 blockwork columns on a house that has been built by a german house builder . The main house is a thin coat ewi system but the client has added the columns to form a gateway at the front of the plot . What base coat would you recommend ? Cheers
Alsecco is a trowel finish render, not float finish. after the trowel you can bring a light sponge over it.
we used a MR base coat
Thanks Malc , The finish looks like a 2mm bucket coat trowelled. Did you have to use a primer over the base?
Plastic to rub up or stainless all the way ?
dont rub it up, if you try to rub up the material will drag. no plastic.
lay on with a stainless trowel , a carbon trowel may leave a dirty mark on the finish. lay on like skim, tight , trowel finish, you can give it a light sponge if you prefer, after the trowel.
Alsecco on block work was done with TZ1 haven't used it for a few years but I thought it was a good product.
Thanks guys , I think I'll have a try with a bit before doing it. Its a pretty rough textured finish possibly from sponging
Tz1 backing then there topcoat its just an acyrlic finish rubbed up with a plastic trowel i have used tons of it in the past
