Wondermitre
chris16
Are these any good was having a look at one online and get head my head around how they work? :o
Screwfix have a mitre block designed for coving and was wondering if this would be better
i use the wondermite, works a treat mate also dosnt take up much room in the van. plus made from metal so its gona last longer than one of those plastic mitre blocks
The one from screwfix says it only does 45 and 90 degree angles is that all you need
Does the wondermitre do more angles
Also what about the end pieces when you stop a run of coving
i tried a plastic one once, didnt rate it, though the metal version is ok im lead to believe..
end of the day, anything other than 90 degrees (or near enough) and i use a tape measure and a bit of treewood to support it while i cut it..
I swear by the metal wondermitre best tool i've got.We're doing artex cornice at the moment fiberous shite and you use a mitre box for that i think there crap and the more you use it the worse it gets.I suppose it's whatever your used to.
