gooner59
this diagram show the mesh against the insulation and not set into the render ? http://www.greenspec.co.uk/insulated-render.php
You bed the mesh into the insulation
What system would u put fixing through mesh.ive never redn nr done that
i agree the mesh would on most system go into the top of the base coat you just hide it under the surface, but would it cock it up if it was under the base coat as in the picture ? as surly the size holes in the mesh are big enough to let the render bond to the insulation !!........
