should I use the corner trowel after flattening the second coat? Or is the wall still too soft then? So should I do it after the wet trowel instead? Would really appreciate some advice, thanks.
After the second flick with water for me no need to put tramlines in the gear doing it too earlyshould I use the corner trowel after flattening the second coat? Or is the wall still too soft then? So should I do it after the wet trowel instead? Would really appreciate some advice, thanks.
Thanks matei use it at the start of the set mate to get the shape
then towards the end to keep them neat
no need after each trowel brother![]()
whats a corner trowel
Hobo only gets them in his briefs now don't ya you dirty dogThink he is talking about a twitch !
Premature twitching has been a problem for me in the past. I hope that putting it out there will help others in the same situation.
dont wear briefs im always ready to goHobo only gets them in his briefs now don't ya you dirty dog
sticky tape your big problemPremature twitching has been a problem for me in the past. I hope that putting it out there will help others in the same situation.
there are other names for it!
