Tyrolean mix/prep
Jmcl101
were doing an old cottage at the moment and with a scat/Tyrolean finish (not cullamix just knocked up ourselves to match the dopey old existing !
I work with 2 other olasterers and we all have a difference of opinion on the following >
1) how to prep the ruled off coat for Tyrolean. Do you guys devil float it ? Normal poly float ? Or just run a sponge over it after ruling off ?
2) how do you mix up the Tyrolean ? (Like piss obviously, but mix ratios ?!)
We all had a different method. Interested in what people say here ! Let's put the cat amongst the pigeons !! :)
for sand and cement tyrolean, fit beads and scratchcoat on day 1,
day 2, render wall, ruled off and with a once over with a poly float . we use the same gauge that we used for the render, knock very wet and a light spray. on the same day that we apply render so that it all goes on in one.
i do not worry about infil spray of the tyrolean when i spray sand and cement as when it is painted it will look good.
Tyrolean mix/prep
