Tyrolean Finish
xyzplasterer
Anybody know a lime mix that can be used in a Tyrolean Gun?
I re rendering half a house using lime (the old part) the new part that doesn't need rendering has a Tyrolean finish, I need to blend old into new.
As Malcolm says mix up wet and tyro away.i like to do it same day as top coat,then another next day to finish off.
You spraying lime render aron?
Think I'm going to go the haired mortar or more likely Eco Cork from Mike Wye. I've looked into machine products but for this project I think hand applied maybe best, I'll let you know!
i would spray same days as render, a light coat of tyrolean as it is all the same colour so no need to cover the entire render coat.
