tripping
Q1 is your main motor . how long befor it trips if its instant it could be broken cable to the main motor or your main contactor as got carbon build up or worse case your main motor is burning out. If ut trips after a while check you have the right volts coming in from your geni also check your back pressure this can cause your motor to trip if your pressure is to high .Or better still call me when your with the machine so i can fault find with you on the phone.
