kirk johnstone
YOU SHOULD TRY THREE COATING WHEN YOU ARE RESKIMING IT JUST GETS THE WALLS SO MUCH STRAIGHTER, OK IT TAKES AN EXTRA 30 MINS PER HIT BUT THE JOB LOOKS SO MUCH BETA
madmonk said:never lol![]()
kirk johnstone said:YOU SHOULD TRY THREE COATING WHEN YOU ARE RESKIMING IT JUST GETS THE WALLS SO MUCH STRAIGHTER, OK IT TAKES AN EXTRA 30 MINS PER HIT BUT THE JOB LOOKS SO MUCH BETA![]()
kirk johnstone said:come on then lad, no secrets! spit it out![]()
Render Systems said:if the walls are that bad then you should give them a tight coat of bonding first as 3 coats of skimming is to thick
quote]exactly its not really designed to go on that thick its too brittle at depth hence thats why bonding was invented by the lovely bg
Yeh probably a toilet after you've emptied the plaster ;Dkirk johnstone said:well am dead good so i can do it, i onley hav to look at a bag of skim and it turns into sumthin beautifull![]()
skimmin2day said:3 coats of skim is to thick???? what about overskims sometimes 5-6 coats??
Im not condoning his stupid 3 coat technique,but there is no reason i see why you cant do it if you got the time and not capable of doing the job proper in 2 coats.
madmonk said:kirk are you desperate dan in disguise ;D
del said:Got any more good tips kirk ?...............FFS
del said:I did, and still recovering.............What name do you normally use on this forum ?
absolute gold...kirk johnstone said:del said:Got any more good tips kirk ?...............FFS
mix multi finish with paint an it will save the decorators a job oh and another good one is, if there is any tight places where you cant fit your trowel in-skim a bit of board in the back of the van then cut it to size and dab it in place. they taught me this on my two week course. if i think of any more al let you know del
anyway did you have a good new year mate![]()
Chris W said:absolute gold...kirk johnstone said:del said:Got any more good tips kirk ?...............FFS
you dont think you could adapt this technique to skimming full boards at home then dab em on the wall and fill the joints with easy fill??
you should write a book mate.. ;D
Chris W said:my skimming is that crap i usually have to go back and pva it again so its usually 4 coat....
you havent got any tips on how to get a wall flat with one coat of skim by any chance? without using a sponge is poss cos i wore mine out :-[
del said:ERRRRRRR kirk 'me ole mate' after 27 years pushing shyte up walls, don't think i'll be doing 3 coat skim work mate.
kirk johnstone said:del said:ERRRRRRR kirk 'me ole mate' after 27 years pushing shyte up walls, don't think i'll be doing 3 coat skim work mate.
i just love
i live for plastering.
27 years, you must av done some running in situ, can u give me any tips as am going to have a go at it at home over the next few days before i start work again.![]()
flynnyman said:kirk johnstone said:del said:ERRRRRRR kirk 'me ole mate' after 27 years pushing shyte up walls, don't think i'll be doing 3 coat skim work mate.
i just love
have you ever done this type of work? have you made a mould? are you gonna use a muffle?
kirk johnstone said:flynnyman said:kirk johnstone said:del said:ERRRRRRR kirk 'me ole mate' after 27 years pushing shyte up walls, don't think i'll be doing 3 coat skim work mate.
i just love
i have made two templates and horsed them up one a few mill bigger than other so al core out with small one an finish with big one, i have set running rules to the walls after i laid the screed on my ceiling but thats as far as i hav got up to now, oh an today i was trying to make some joint rules for stopping in the angles, but no av never done this before and i did want someone to teach me, didnt get much response so i thought al just have a go anyway. its in my own home so if it (german word)s up it will be ok, but if any one has ant tips or wants to teach me please do.![]()
