the best product for tanking cellars
RMK
if money was no concern which company/product/system would you use for a cellar conversion in a stone outer/brick inner terraced house.
Best solution, a membrane system ( Newton or similar). From my experience, cement based systems that deal with positive water pressre are only as good as the substrate behind. With too many variable to consider, a membrane system with sump pump can be fixed to any substrate easily.
as Henry said K11 is the bees , but as Mark pointed out you do need a lot of surface prep if the substrate is not up to scratch which usually makes this system cost inhibitive, but it is pretty much bullet proof if done correctly, and you don't have to worry about a sump pump failing, blocking etc
