Hello everyone,
I'm renovating a very old room in Southern Italy and have a strange issue with a wall I'm skimming. The house has tuff stone walls, and the existing plaster was in good condition.
I had a small section with peeling paint, minor mold (likely due to a thermal bridge), and some cracks.
My process:
I've done other small fills in the same room with the same material and had no issues.
I'm planning a third coat, but I'm worried.
My questions for the experts:
OTHER INFO:
- The shaving was done in the late afternoon.The photos are almost in the evening; I admit the light makes things worse.
Photo A: Wall before
Photo B: First coat, wip
Photo C: Second coat, final
Photo D: Second coat, but with flash and zoom
- The old paint is water-based. The paint on the wall adheres very well. It won't come off with a spatula or paper.
- In the first hand ZERO problems.
- On the second coat, I admit I didn't work the filler enough and didn't let it rest after the hasty preparation. I was late.
Thanks for your time .
My process:
- Removed all loose, peeling paint.
- Treated the area with a mold disinfectant.
- Sanded the surface until the old paint was well-bonded.
- Applied the first coat of simple powdered filler. It dried perfectly.
- After 30 hours, I sanded with 120-grit paper.
- Applied a second, thin coat of filler.
- What is causing these damp-looking patches?
- Is this a sign of an underlying issue, or is it normal?
- Will these patches reappear after a third coat or after painting?
OTHER INFO:
