Plasterite
I’ve got 48m2 of St Anne’s brickwork to render (external plain face) very tight beds and perps, aprox 5mm, brick is semi engineering / glazed, thinking of using sbr, rib lath and k rend, not used it before ? :-\
thanks McPlasterMcPlaster said:Tight coat of HPX, its got fibres in it for strength, good stuff, and if your k-rending it anyway same manufacturer and the jobs a goodun.
youve mentioned this before goody could this be the death of base coats ???goody said:or you could use parex microgobetis which is a solution meant for giving you a key on smooth concrete etc which would suit the your bricks too.....just roller it on and render next day
