You just use the gun for mono, i've seen posts where Grand Wiz has said hardwall is difficult to spray and i agree, some how the mixer pump makes the material a little creamier, however if i had a lot to do i rekon i'd get used to it!
Doesn't set as quick just like using the joddy, but if you had to float something late in the day you would with a ritmo because it's easier, you won't do anymore but you'll last the course, it's easier with a mixerpump.You aint shagged out before you skim.
spraying hardwall and skimming by hand is the perfect example of how the two methods come together to give you one hell of a productive day that you can handle day in day out.......lovelly
