Spraying. Brick effect mortar coat
Only way ive ever done it mate done loads in the past ewi.got one to price up it was just a thought to see if anyone had done it this way.,obviously not the brick coat just the base
You maybe able to spray the mortar colour base but with the brick colour coat only being 2-3mm and going onto a softish base I would hand apply it.
has anyone ever sprayed mortar coat for brick effect or would be too much of a fanny on with you forming corners ny hand
If you are using K Rend the spec says you can spray both coats , I guess it depends on the amount of area you are spraying and how you manage it.
You could spray the brick face coat onto the mortar coat and flatten with a speedskim rule or similar.Dont mess about with the brick face coat too much though.
