Spatula pole attachment
Rossw21
Anyone know if/where you can get an attachment for one of these to put in a pole? I've seen them in the past but can't seem to find one! Cheers
Yes, Ramboo sell them, and you can also find them on eBay (search for 'broom bracket'), but you ideally need to get a spat that has wide-spaced mounting holes (unless you're happy to drill your own holes).
Link Removed
The Refina spats used to have wide-spaced holes, to receive a mounting bracket, but don't seem to these days.
The SuperProf soft grip spats might suit your needs, but probably best to double-check compatibility before you buy. If you dig around on eBay, you can find some other spat makes with mounting holes, too (e.g. #153813846229). Be careful you don't get caught out wrt blade thickness; some of these traditional-style spats come in 0.3, 0.4, and 0.7mm variants. (y)
