stolen stilton
Hello all. Have quoted to soundproof a big ceiling in a house. I quoted to rip down existing, insulate between joists with 100mm acoustic rock slab, board over in Soundbloc board and skim. Customer has accepted but asked if it is worth spending more and upgrading by putting an extra 50mm of slab in and fitting resilient bars to the joists first so a couple of questions.
I have not used the resilient bars before so is it just a case of screwing them up along the lengths of all joists and then screwing the boards to these.? Do the bars come predrilled with holes for the screws to through? How much do they cost and where to buy them from?
I quoted to put the 100mm slab into what is a 200mm cavity as I believe that an air gap between the floorboards above and the slab is the best way of achieving the sound insulation. Is there more soundproofing to gain by adding the extra 50mm and leaving just a 50mm air gap?
Sorry for the questions but not had much to do with soundproofing before.
They are just trying to negate the noise in their own house between floors, it is not a separtae dwelling above
Many thanks
Many thanks
