Skimming over old browning / bonding.
Chris Fowler
Folks I'm after your wisdom
I'm no plaster, but I'm fairly competent in skimming over plasterboard.
Doing a kitchen at the moment and the wall isn't the best.
Got the tiles off and under is a flexible grey coat of who knows what and under that, the original browning / bonding coat.
Rather than rip everything off I want to skimming over it. As its quite old (and a little crumbly in places), do I use a week mix of pva and water just to hold it together, or just a coat of pure PVA to seal it then crack on when its dried.
Would be really grateful on some advice on the best prep for skimming.
Thanks all
Thanks all
@themucky1
Thanks all
Thanks all
Mix some strong pva 50 /50 water and a tight coat of bonding then skim it
Thanks all
Yes
Fuk using pva full stop . Tack dab n skim fuk that domestic dogshite. Tools coated in bonding and pva all day . No thanks
Winters coming, enjoy the site work mate.
winter is coming GIF
Bonding is horrible stuff for tools, worked on a site and the spec was Bonding/carlite finish.
So you float in the morning, but the changing over to finishing in the afternoon was a pain in the arse cos you had clean everything within an inch of it's life.
Yes used to do loads of floating in bonding years ago fukin awful mixing in a bath . Fook that nowadays must have been insane
