skimming moisture fireboard with knauff decoplus
chequers
Hi all
ok 70sqm ceiling up with siniat moisture fireboard 12.5
Had the tapered edges all filled with easyfill and sanded
getting ready for plasterer to spray knauf decoplus BUT
should I apply bond it or similar on such a big ceiling in a moisture filled room
In my mind I think the bond it will assist but I dont want to mess up , the plasterer thinks spraying decoplus straight on the board easyfill will be fine ?
Thanks all
I think @Curry said you can spray this straight on with excellent adhesion but you could roll on some betakontakt if you are unsure.
