should I PVA after febond blue grit?
legepe
Hi all,
I have prepared walls and ceiling with febond blue grit and I just want some confirmation that before i skim over with multi finish - should I PVA over the blue grit or will it be ok to skim over it dry?
legepe
Hi all,
legepe
no... skim straight over it buddy :D
You didn't say what the background was before you gritted it, if it was high suction you should put pva on before grit, but never after
I don't know what is under it. I have to look at it tomorrow. They got rid of the plasterer that was doing the job. His work wasn't great so am told. I didn't know you can't pva over blue grit tph.
Mine was for the op Keith.
Yours I would just lash it on as you would know what to do if it started sucking in etc. Get it on!
Sound. I have a few packs of extratime could be a good way to test it.
