Shadow gap beads
johniosaif
starting a job soon, 3 new houses, they added shadow gap beads to the job around the door frames and along the stringer , they thought I could put the shadow gap beads before they fitted the frames , I suggested ,frames fitted first then the chippy to fit the beads as the are cut at 45s and need the right chopsaw metal blade . What say you
Up to you but I know a man of your caliber is well capable
Junior hacksaw and a tile trim mitre block to cut the beads. And yes deffo get the door frames fitted first.
If anyone has to put them up here's a little tip that worked for us. Cut the top bead straight and only mitre the sides. It makes the joins look spot on. Even cutting them with a mitre saw you tend to get little gaps where nothing is ever dead square.
we plastered a hospital with shadow beads around doors and at base of the walls, to give the walls a floating effect. on completion the NHS would not accept these as they are a dust trap the last thing you need in a hospital !
My mates in Sydney and this is all they have they don't have architrave, have a gooogle and see if there is a uk suppplier.
Definitely with frames in first, personally wish I'd gotten chippy to fit first. I didn't get on with the mitre saw, they made a really nice cut but nothing is ever truly 45degrees. I found putting the head on first then marking the 2 up rights and cutting with a hacksaw and touching up with a file. Came out nice , like everything got easier as it went along . Stairs were fun.
I Found they always crack around the doors the shadow bead detail.
Had the opportunity to try and Do the last couple a bit different and it worked out a lot easier I thought also cheaper on the beads and not a single crack anywhere.
started with a slighty Over sized opening then screwed a narrower rip of timber round the frame first fitted the door lining then cut the board to the edge of the inside timber and then before fixing the board slipped a board edging bead over the board then fixed it.
Shadow gap beads
Shadow gap beads
Perhaps not the usual way of doing it but worked out well.
I did something similar along the stringer where it met some stairs, I stuck a piece of doorstop to back of board then slid a 553 edge bead to the board, probably makes no sense but worked a treat
We were doing float and set when using this method, obviously no need on board and skim.
