windy
Have a wall to look at. Customer said there is salts showing through internal wall. Caused prob by penetrating damp as the pointing was goosed and this has now been re pointed.
Problem is it is solid wall no cavity built with breeze bloc on interior. Existing backing plaster and skim is only around 6mm . So can only be hacked off to the same extent. Now pointing is what backing coat would u use. S and c not a not an option due to existing plaster depth?
feckin what ever you use you could only get one coat of being on before skimming? What about drywall??
any suggestions
also if backing plaster is only thin can salts contained with in blocks still show through?
thanks in advance
any suggestions
thanks in advance
