It's a miracle tool,it will turn any dole dosser into a highly skilled plasterer the first time they use it!!just hold the handle,aim it at the pink stuff and away you go. Easy as that!! Don't tell everyone though try to keep it on the low
Yawn!! You dont need a instruction manual just use ya noggin!
So how would you use it? First n second coat applied then trowel up with the super flex as normal. Or do u trowel up 3 times and if it's still wet leave it as its good enough to paint. ?? Help pleaseGives your more time also u can make more brews and start later on job n finish earlier !!!!
How I use -first coat good base on any surface lay on 2nd I found I then can use s*p*r*lex with in a few minutes piece piss after enjoy don't forget yer brewsSo how would you use it? First n second coat applied then trowel up with the super flex as normal. Or do u trowel up 3 times and if it's still wet leave it as its good enough to paint. ?? Help please
When I say wet I mean where it's not browning off as near as set hope that helpsWhy would you trowel it if it's wet?
You use the s*p*r*lex for the last two trowels, arguably later than you would the mt, for the next to last trowel at least
I'm no expert with the s*p*r*lex but doesn't it blister if you trowel too early?
For me I'm doing a job in morn I've got a easy gauge In the sense I have a 3x4m wall and a 2x4 ceiling to do, it's on blue grit too I think I will be leaving it longer then normal as it always blistersIt's ok saying give it 5 mins but how much have you got on? How long have you spent laying down, 10 mins or 40 mins? And if your relatively new to sf you should definitely be using mt for first trowel, (IMO always)
You won't get any more work done with a sf, it's just easier.
it then I'm thinking if it's going to blister ignor it and trowel up as normal but then at end tilt edge of blade more so it scrapes the bumps away the polish of at end?
How come u r using blue grit all the time r the walls that bad ??Yea that's fine good advice. Can't do it today with the blue grit as its already been applyd. But will trowel up with SP and if it's blistering back end of set will open blade up with my MT. Cheers hopefully from now on I can crack this with the blue grit.
