rsj
ruddez
does anyone box in/plasterboard rsjs themselves before skimming if so which method would you recommend,thanks
I usually cut noggins that I wedge in real tight into the web of the steel. This gives me something to fix the board into. I'll over sail the board so I can fix a baton through it on the underside of the steel. Do this on both sides of the steel and then you can fix a board on the underside into the batons and then knife off the excess board and give it a surf off.
Upright Soldiers then either grip fill underside or depending on how far the soldier stuck out screw to the bottom of them
before h and s went crazy we would hilti gun timber to the rsj then tack. now we cut soldiers in the flange and dry wall adhesive the soffit.
