Cheers ianTry leaving it in a bucket of water over the weekend see if that dissolves the crap. There are mortar dissolver sprays that can help that arent harmful to ur equipment for a more rapid solution
its the moving bit where the hose connects to the gun ,saves your arm getting twisted when the hose moves about ,if you know what i mean matewhats a rotating coupling........................?
Allows ur spray gun to rotate 360 without turning the pipe aswell. I think it's a must for long guns but also handy on normal size getting in a tricky spotwhats a rotating coupling........................?
you put it a lot better then i did !lolAllows ur spray gun to rotate 360 without turning the pipe aswell. I think it's a must for long guns but also handy on normal size getting in a tricky spot
you got one of the long spray guns yet John ?Cheers Machine Marra's................
Not yet marra. is it like a lance type thingy ??you got one of the long spray guns yet John ?
Yea mines 1m long spray 3m high easily mateNot yet marra. is it like a lance type thingy ??
