Rollers
irish_spread
Dunno if any of you lads can help but I'm having problems with my Pva roller. The sleeve is fine, albeit a bit hard in places. The problem seems to be with the roller cage. When I'm pva'ing it seems to. 'Jump' on every revolution, I'm thinking it might be a worn bearing or something ???
anyone know if I can just buy a new bearing or would I have to get the whole cage reconditioned ?
it wasn't a cheapo BnQ value one either, I got it in Wickes, it's got their name on it
thanks in advance chaps
think you need to contact the roller rapid technical helpline marra.............lets us know how you get on...................:RpS_unsure:
I think you need to get out more often Irish:rolleyes)
How long you had it mate ? is it the Mk1 or Mk2 ?
The Mk 1's are notorious for the bearings playing up, you'd be as well to put it in for a service and get them replaced, if you try and do it yourself the warranty will be void. :RpS_thumbup:
Send it to me ,as its you I'll repair it for 50 quid.
I had this very same problem a while ago so i sent it into the local paint application tool dealer for a service. Turns out the giggling pin had sheared off the laughing shaft , could of been a nightmare ending up with pva running all down me sleeve an that.:RpS_mellow:
try unifinish no pva needed:RpS_thumbup:.
heres one, how old is your pva roller without having to change sleeve
Roller? We can't afford one of those!
1) Mix P.V.A with water in bucket.
2) Chuck contents on wall.
3) Spread over wall with sleeve.
4) Job done!
