RitmoL
spunky
Not sure if I dreamt this but are pft thinking of bringing out a ritmo bigger than the standard one but smaller than the xl ?
go on spunk just buy one u know u wana. get the machine then find the work go for it mate, i know ur in love with them since u used on
so spunk you still got a taste for them orange contraptions then butt? got my eye on a ritmo L but am sceptical it will do as a primary pump as considering how many times the 5.5kw motor has got us out the sheit on the xl, the 2kw just wouldn't have budged. ps, we have stopped drowning the poor thing now though lol. Also id say that anything stiffer than a D43 clamp r&s would be a no no for it( the xl loves these but not so much the d52.2 and especially not the d63!)
The Ritmo L is the same size as a normal ritmo but with a 2kw motor. The larger motor means that you can use D pumps on it instead of the specialised B pumps. It hasn't been mentioned for ages so don't hold your breath.
Everything these days is getting smaller and more efficient init so a beefier motor on a smaller machine that plugs into mains or even running off a smaller more economical genie is a good thing like
I think you can only use D pumps on it and the speed control gives you a huge range. When a bit more is known you will be able to tell how much material it is capable of pumping when using different rotors and stators. I think they will favour the D5-2 for all round use
You gotta say though that if it was a competent machine it might make the rest of the bigger machines look a little obsolete. I wonder if commercial factors will play a part in the development or indeed lack of development of this machine.
Good point either that or there still flat on their back in shock cause it worked when they turned it on
