Ritmo water problem
Andy M
Fired up the Ritmo yesterday but unless you press the flow meter button it wont put water into the hopper when the motors running.Connected it through water pump and also mains with good pressure but still no joy.
Is it fooked or something im doing wrong?
Heads up to John S for helping out yesterday.:RpS_thumbup:
Ok So to tick off the checklist.
You have water pressure showing on the water pressure guage
Water comes out of the tap if you open it to fill a bucket
The water switch is definitely at the position to use as a mixing pump
When you press the water button you do get water coming right through to the chamber.
If all above is as it should be then it is possible that the contactors on the back of the water switch may have become defective.
Open the caddy and look at the rear of the water switch and you will see wires going into contactors try tapping them where the wires go in and try jiggling the wires
Nice one Ian,water supply back, jiggled the wires and put contact spray on the connection. Could have been a sticking relay?
you should change them really Andy, once they have gone once they will likely go again but during a spray. they are simple enough to swap for peace of mind
