ritmo porn
plasticfantastic
How do you get a ritmo hose to shoot its load with out its being on the machine???
Drive a transit over it sorted:RpS_thumbsup:
NOW lets try flushing it agen
How much is the painting stuff for the ritmo? And a purge kit??? And the mixing chaber cleaning shaft (which should come with the powercoat kit more so then the rimto M imho)
Speak with Stuart, he will get you a quote for this. As for mixing cleaning shaft, I believe that this is because the 'rest of the world' have no need for this, maybe the need is for UK only and I will need to look into this. Always good to get feedback from the applicators.
When spraying finish the material gets baked on around the mixing zone and goes off. Every time we do a hit we have to take off the skimming r/s and crush/clean out the rubber mixing zone. This only happens with gypsum based stuff. When we spray renders the mixing zone is easy to clean so I don't get why it comes with the Ritmo M package as standard but is left out the Powercoat package Why does the UK need this only?
The plasters they make in Germany have much longer working times so they don't get as much build up has we do with our product ,. If you look at the price of there skim coat it's about £12 per bag so it makes you wonder what's in there .
Thanks les. Do you think the cleaning shaft will clear all of the baked on plaster of he mixing zone?
Oh and we do want that Clarke compressor by the way
Yes it will clear any old set plaster . I will look to see if I have an old one if so you can have it for the cost of the delivery to you .
