Ritmo l
Arti
The L is mustard..............................sprays rendaid like a dream and runs like a sewing machine
Rigsby
TPF Special Forces
It will spray all but not all as a basic kit. Some materials will need add on's like a bigger compressor and texture guns. Extra £'sssss
tottiman
how long can you spray rendaid before cleaning the machine. When manually mixing it by drill, you need to keep on top of keeping tools clean
Arti
a fair few.......just sprayed till lunch, cleaned it out then sprayed in the afternoon
Rigsby
TPF Special Forces
I have sprayed Kilsaren Super Bond their rend-aid equivalant. It was a few mm thick then meshed then a light spray over and scratched.
But as Weber like rend-aid stippled as a key I have thought maybe pre mixed and sprayed on with a texture gun through the Ritmo? Not that I am likely to use rend-aid if I can help it. May have a job coming up that has to be Weber to match existing so just a thought?
