render too low
kwakarider
hi there, will it be OK to use an angle grinder to to cut a line in the render horizontally at the bottom of house wall to remove the bottom 4 inch. this would leave no bead at the bottom of the wall.
would this cause any problems ?
will the bead need replacing ?
if so how is best to replace ?
thanks jackie.
000
thanks jackie.
Not ideal .. but if it’s dropping off due to render over dpc ..... run a good straight line to @@ dpc level (Then run hp12 or similar ) up to cut
You won’t replace bead without patching into existing render , would look shite ...
You could turn a stop bead upside down (not ideal).
Then render up to bead in hp12
Monkey Boy
do ye ride a kwaka?
kwakarider
j
the house has is old stone. would like the render on the right to be level with the left side ?
Lastlaff
j
Looks like your angle bead meets the horizontal bead (doesn’t look like a bell cast), if so, just cut a straight line and it will match the left side. Is it new render?
Used to have a Z750 hard tailed then a Z1000 - best bike I ever had. I’m a sad c**t without a bike too now.
kwakarider
thanks for the advice that's what I will do. 12 month old render not the best workmanship. had 2010 z750 loved it too.
