tapit
Just need couple of wraps of PTFE then.im sure those horizontal features will be compression joints
No, no, they should have been blue gritted. Basic stuff.Yes mate was 9.5mm plasterboard, was told that would be fine as long as I pva'd them first![]()
A lot of "no comment " from Knauf reps. The board manufacturers rep didn't show, not sure on the make @GrantyBoy . Samples were taken for analysis. A couple of other sections are starting to delaminate . Application was followed to spec. Lots of headscratching going on.how did the big wig meeting go @Olican ?
Mine too , everything else is by the book. Have to wait and seeif it was a spec given to you then its their problem. aslong as all.components used are as per spec then your free as can be.
fact that the renderboard manufacturer didnt show isnt good on their part.
think the blame.will point towards whoever provided spec first. but be interested to know the boards used. ive seen some builders get mixed up and use cp boards rather than renderboards before. my money is on that at mo
What were the beads fixed with Oli?Mine too , everything else is by the book. Have to wait and see
Don't like plastic beads due to their higher thermal expansion , stainless is same as concrete , another irrelevant fact lolWhat were the beads fixed with Oli?
Plastic bead on a nice flat board seem ideal for you know what!
yes but metal has higher thermal conductivity.Don't like plastic beads due to their higher thermal expansion , stainless is same as concrete , another irrelevant fact lol
I might be thick but that's an advantageyes but metal has higher thermal conductivity.
not really because it means potentially the metal bead will expand quicker and expand more.I might be thick but that's an advantage
I saw it as it will transfer its heat to the surrounding render more efficientlynot really because it means potentially the metal bead will expand quicker and expand more.
fook knows!I saw it as it will transfer its heat to the surrounding render more efficiently
but the holes in my tape will acomodate
fook knows!
I thought I was the last person still using stainless beads.Plastic beads require more physical area than metal , the render doesn't bond to the surface of either so plastic creates more potential moisture ingress capillary problems,
You probably are lol , price kicked it out , coupled with people's poor rendering,, scraping galvanized causing rust issues along with misshandeling by suppliers and labsI thought I was the last person still using stainless beads.
We find that lots of clients love the idea of having stainless beads instead of plastic, sounds quality.You probably are lol , price kicked it out , coupled with people's poor rendering,, scraping galvanized causing rust issues along with misshandeling by suppliers and labs
nearly forty years, that's long enough, we don't want to put the next generation out of work.We find that lots of clients love the idea of having stainless beads instead of plastic, sounds quality.
We're currently working on a chop off re-render, loads of the galvanized drip beads had turned to rust. House built in the early eighties.
Surely people can see this is a design fault ? Nothing to do with any render board or render ? The timber frame has expanded forcing the boards offRendered a timber frame block of flats 5 years ago and one elevation has delaminated from the boards and shelled off.
All the work was carried out to spec, rest of the job is sound.
I'm in the clear on this one , the contractor is not looking to me for responsibility I'm just curious as to what could of caused it. Site meeting on Wednesday with Knauf, the render board supplier and a few other suits. I'll be keeping my mouth shut. Looks like it'll be an insurance claim.
Base coat up210 hand applied, fully meshed onto top 1/3rd of base coat. Materials mixed with clean tap sourced water. Sufficient curing time before toping with Knauf mamorit
For panels to do this it’s got to be movement in the timber frameeasy to check..... is your phone wet? lol
to be honest a whole elevation to delaminate suggests wrong boards/basecoat i will imagine they will want to see compatability paperwork which should be on their bba.
i did think knaufs basecoat was sm700plus. but been a while since used
It all went quiet, I've not heard from anyone. I followed the spec to the letter, I think it could be the boardsHow did this story end?
How did the plastic surgery and name change go mate?It all went quiet, I've not heard from anyone. I followed the spec to the letter, I think it could be the boards
A few things to get used to.. people calling me SusanHow did the plastic surgery and name change go mate?
