Reliable machine?????
Fergal
Tough day at the office, first day using my little Hama spray machine I got for thin coat systems, as soon put material in it tripped an I couldn't get it going again, though these days were behind me when I switched to diesel power
are the ritmo's as temperamental?? Maybe should have got one instead
Aye 110v 32a I'm running off a 10kva gen should be more than enough, material was nice a pissy, stator wasn't tight, I'm going to send it up to Hama company in Lichfield that deals with them, prob won't be cheap
Does the machine trip out the power on its own or only when the compressor comes on.
Those 110 v compressors are heavy duty. It may be that. Check the size of the trip switch on the generator. It needs to be at least 25 amp
Naw man it's definitely the machine, compressor and machine were working fine when I put water in the hopper, then I disconnect the compressor when I was workin at it I had to push the circuit breaker button in just to get the machine cleaned out
