Re-coating shoddy damaged Krend
Jrend
Been to price a job over the weekend and the customer is very unhappy with the quality of work left by previous renderers.Also he has had a new pattern imprinted driveway and they have got black pigment all over render.What system would you use? I have talked him into using bucket coat with a primer first but some of the panels are bumpy and some deep scratcher marks or would you micro and 10 mm mono over the top? The insurance company from the concrete guys are footing the bill so price isn't really an issue.
Cheers
If there paying can't you hack off and redo so you know it's done right? Chances are if they were bad at doing it it may not last so your only as good as your backing!
Hack it off :) as @JGREEN says only as good as the last coat....
Insurance work :) £££££££££££££££££££££££££££££'s :) :)
I personally wouldn't be putting another 2 coats over mono
Mr systems I agree with Maite then 1.5mm finish
Less weight and Maite will got come away for s**t
