Had to take some plasterboard off in my conservatory which was put on using dot and dab to replace pipework to radiators.
While i had this off ive decide to run hdmi cables etc to a tv on the wall so ive ripped the rest of the plaster board off and intend to replace it using battens fixed on to the wall so i can pull cables through in the future if need be
im reading conflicting opinions that i should insulate the wall between the battens or not . im going to use either 19mm or 25mm battens
before i proceed to fix the boards on can someone give me a definate answer.
