How tiny is it marra?
The wall I mean :RpS_unsure:
For details on prompt cement see Rapid quick setting Prompt Natural Cement there are other suppliers too, this is just a good example for educational purposes.
OCR marra?
@ARTisan, You dont seem keen on using prompt? Just mix up prompt 1:2, dub out your areas with it, wait til it sets 15-20mins max, then go about your scratch coat in your usual manner (s/c straight on top,) return following visit and top coat.
Examples of Use
Accelerated building operations, emergency repairs, rebuilding of openings, quick build up of any type of masonry, quick or rapid (use of Tempo), very useful for fitting doors and windows. Underpinning operations, with a higher compressive strength than NHL based lime concrete or mortars, and with a much quicker set allowing for safer and improved productivity, all without the need for OPC.Where to use Quick Setting 'Prompt Cement'
Prompt Natural Cement can be used in countless applications on its own, with sand or gauged with traditional lime mortars and plasters, lime putty or NHL mixes, along with many other applications in building conservation where accelerating or achieving a rapid set would be beneficial.
It just says without the need for OPC, not dont mix or gauge with OPC, ive always gauged it with OPC if I require a quick set or same day finish. They are focusing using it with lime because A) Its a natural cement and B) There isnt many products that are compatible with lime. Give it a try mate and I bet you will always keep a bag spare in stock for a rainy day. Bloody hell, prompt should be paying me here for promoting their product lol. What ever you decide, best of luck with it mate.
its a canny bit to dub out and having not used OCR before would i be able to dub out and scratch in the same day??
might just go with the frostproofer option as it seems these rapid cement's might crack?
Im still no farther forward...............:RpS_laugh:...............FFS...............:rolleyes)
so you reckon it will be sound to use it to dub out in the morning then scratch the wall as normal in the afternoon with out it cracking the scratch when it cures?
How much you gotta build it out?
Here try this accelerator it takes 5 minutes to set diluted :-0
Or 30 seconds to set undiluted :RpS_scared:
Link >> Vandex Accelerator - Accelerating agent for Portland Cement
No never used it marra.
You could whack a load of sugar in that'll accelerate it :RpS_thumbup:
Look:
http://www.sciencevision.org.pk/BackIssues/Vol8/Vol8No1/Vol8No1_09_Effect_of_Sugar_BazidKhan.pdf
