Quick one for the PFT guys
Andy M
Would the Ritmo 1.3 Powercoat motor be capable of pumping render as Ive noticed the Ritmo M has a 1.5 kw motor?
I understand there's a render conversion kit for it. The pft guys will definitely be along soon enough to answer it for you! If not let me know I can send you a number.
As far as I know the powercoat is 110v only. This comes with the skim setup but you can get the guns and pipes to spray render and acrylics which all works fine with any material we have thrown at it.
The ritmo m comes with the render setup but you can by the skim setup and thin coat setup. This is available in 110v and 240v.
Sent from my HTC EVO 3D X515m using The Plasterers Forum mobile app
Powercoat comes in 240 aswell Steve.
Sods law though we have job next year that we are only allowed 110v.
If its finish your spraying at 110v then getting a ritmo shouldn't be to hard. It's the 110v air compressor with a high enough output that's the issue. If you need a hand give me a pm or call.
Yep Sussed it in the end thanks.
Once we got the correct size 110v box and set the machine to speed 6 were away no bother
Ritmo M is standard set up for render and backing plasters. The powercoat equipment consists of different pump unit on bottom that can be changed in a minute, thinner pipe and stainless steel spraying gun. With the powercoat equipment you can only use it for skim.
You can also use a larger volume air compressor and texturing gun for spraying thin coat systems.
If I bought 110v M or power coat what power transformer would be needed
I reccomend a good quality 5kva for the machine and another for the water pump and compressor. If you had no power on site a good 8.5 kva generator is best
