Are these stainless steel? They have another set for about £25 that specify it's stainless291357921302![]()
Link Removed
I've got a bargain then 99p
Hiya pal long time no see lol hope your ok? Yes just bend the corners in slightly with pliers and I'd just use them to flatten between coats first and second plus use them on mono etc. Once "broken in" you can even finish with them (once your used to them)Cheers marshy just ordered a 600 for £7.70!! So what's your process of using them?? Flatten first coat or can they do more?? Do you rub of corners or bend them back
