Built a pond in my back garden used weber on outside top and about 2 inch band round the inside,im fiberglassing the inside upto the mono can i resin over it or not
The best way is Fiberglass inside over insulation up under a coping
A Mono top is going to be manky & 2imch down is even worse will be mouldy black in no time & leaking like a good un
