Tried them mate had no joyamaroc
direct duild maybe
one.stop shop
it looks more modern to use stop bead above a window then bell cast bead.
They are angle bead with the drip built in on one side next to the arrisit looks more modern to use stop bead above a window then bell cast bead.
thats not the one i saw but it looks good if not better than the otherView attachment 16103 Yes wemico it's a balcony bead your looking for mate.
Yes mate I use eps on the face of the original cills and it's for the bottom of the cill that I would like to incorporate a drip.You use polystyrene don't you mate on your render jobs?? Cut a recess in the head using your hot wire cutter so the water drips down before getting to track to the window etc?
