Plastering straight onto brick-not much depth
Nj1
We have had a small window bricked up and the brickie has laid the bricks only a few mm depth lower than the surrounding plaster. What plaster should I use and do I just prep with pva?
  • Plastering straight onto brick-not much depth
Looks like you have a internal & ext angle .
Re do the whole lot between them 2 angles ....
The bricks aren't perfectly straight as it was meant to be covered up so there is some variation in the depth. I'd say between 3mm and 10mm. Do you think a thin layer of hardwall plaster and then skim with multifinish?
Fill it with bonding. Straight edge it through and reskim the whole wall.
That will be one guinea please.
  • Like
Reactions: Nj1
Pva it, bonding coat then skim
  • Like
Reactions: Nj1
