Plastering hall an stairs ceiling
legend22
Hi
I've over boarded my hall ceiling coz of distemper but I can't get a fixing on the 45' bit leading to to adjacent wall can I just wash the distemper all off then pva an skim?
Cheers
Reece
  • Plastering hall an stairs ceiling
There's only Batton around the edge nothing in the middle an the old bit of Board is bowed bad so when I put the new board on can't push it up and fix it
Id screw round the perimeter and some no nail in the middle if you're worried about it bouncing in the middle although aslong as you don't have a joint it shouldn't matter too much. I would use a thin coat stop bead
Use a finish stop bead for the angle.
If you're worried about plastering on that bit, remove the board, put some batons in the right places and re-board.
As above take of the board , pop in a few battons, job done.
Sent from my HUAWEI G6-L11 using Tapatalk
