pft ritmo power coat
roman1
what is yours opinion about pft ritmo power coat .if anybody using this machine for plastring multi finish gipsum is that faster and better than manual method?thanks for your opinion!
The machine works great It will mix and pump it with no problems, then you need to organise trowelling up those extra meters by hand. Its a bit like having a plasterer go home during his set and leaving you to trowel his walls up. A good system needs to be worked out
do you work on pft ritmo power coat use multi finish gypsum ???why is that small amount of pft ritmo in use on construction side
the ritmo is the next new plastering tool . when i started we had to mix with a stick then the bike cogg came along then it was a drill with a welded bike cogg on it . then proper drills for mixing the ritmo is a progression of all these things put together .. So im sure they will become a good selling machine in 2011
