Pebble dashing with modern renders
Mickyboy
Hi guys
Could you use a modern render as a base coat for dashing. If so which one would you recommend and could you use it in one coat application onto brick or block work.
Whats it like regarding holding back the suction , thus giving you time to drop back and dash
Cheers
your better off using a receiver it will hang longer , i've dashed into mono before but you gotta be quick , and most substrates are better off primed then a quick scratch in the mats your using then a butter coat to catch your chippings imo
Hi Paul
What do you call a receiver ?
Just a pre bagged coloured render developed for dashing , nice to use there's loads out there mate , you can also use parexs maite as a receiver as well, if you can afford it !!! :RpS_scared:
Weber makes a one coat dashing render for spraying on. Got be just as fast as the machine though at dashing.
