Can someone please give advice on how best to patch sand and cement internal render under a problem (leaky) window in my 1940's semi?
I think I have sorted the leak bout was going to add waterproofer or sbr to the mix anyway.
The overall depth is approx 12mm.
Will I require 2 backing coats before a final skim of multi finish?
I'm aware that the backing coat must be scratched before applying the second (float) coat. But do i need to scratch the
float coat ready to accept the finish skim?
Timing and bonding advice between coats would be appreciated.
Thanks all
Thanks all
