Parinter
Dewar008
Evening all.
I’ve got a small over render job using parex parinter but the customer wants a 1.5mm thincoat finish, I have been told you can’t use this on parinter.....has anyone successfully used a thincoat finish, if so what’s the best process??
Many thanks
Evening all.
Many thanks
It’s not parex spec ! Should have mattie over the top then prime and thin coat
Yep parinter then a pass of maitie, load of waffle as they claim parinter eats through eventually, but if you've followed the spec you've done your bit.
